A bit more info might help. What sort of price range?
What type? (cover the ear? headband? earbuds?)
(Apple?, or generic).
The stuff I mess around with are the $10 generic headband type, used with
cassette players, radios, etc.
With those, the sound element generally snap into the headband
and if you unsnap each on, there's two solder points.
Color Code for the typical 3 conductor 3.5 mm/1/8 inch plug
green - left side audio - the tip of the plug
red - right side audio - the ring on the plug
copper - ground - the sleeve (two wires, one each side)
The wires are small (40 gauge?) multi-stranded wire insulated with
thermally strippable enamel. In a two by two zipcord jacket.
(Older cords use miniature shielded conductors with red (right) and
white (left) center insulation and no other insulation on the central
conductor and shield wires. This kind of wire can short out.)
The first step it to unsnap the sound elements from the head band.
(I'm not into earbuds, I suppose there's some way to uncap the
end with the wires). Then you can measure between the solder points
on the element and the plug to find the open conductor(s). See
the color code...
One test is just to tug on the open wire and see if it pulls out.
The most frequent breakage is at the place where the wire exits the
headband, about 3/8 inch down. At this point, cut, strip back about 3/4
inch from the break, tin the wire, remove the old wire bit on the sound
element connection, and re-solder. (If symmetry in the cord matters,
you may have shorten the cord and reinstall on the other side too,
or just put a knot in the other side).
The wire isn't that hard to deal with. You need a high temperature
solder iron to strip off the insulation. (Avoid the smoke!). Just
get a blob on the tip of the iron and use that to strip the insulation
and tin a 1/8 inch or less of the conductor.
A lower temperature iron is suggested to solder to the connection points
on the sound element. There are usually two pads for each connection,
one for the headset cord, another to connect to the speaker coil with
VERY SMALL wire, avoid disturbing that one.
Another breakage point is at the strain relief at the plug end.
Often you can fell the break where the wire has a "soft spot" at the
high stress point.
As most plugs are molded on, it's time for a $.69-$2 for a new plug.
Or a whole cord assembly. (I've seen them in Mouser's catalog, anybody
tried them?)
When putting on a replacement plug, remember to put the outer insulator
on the wire before you solder on the plug assembly.
(See color code..., use your ohm meter frequently).
I often reinforce the strain relief on the wire exiting the plug with
some small (1/16"?) shrink tubing. Likewise the area where the wires
exit the headband. The kitchen toaster works good for shrink tubing. ;-)
Mark Zenier
[email protected]
Googleproofaddress(account:mzenier provider:eskimo domain:com)
