Hi, I am currently trying to build a fixed votage output circuit but i need some assistance, i am using the lm2940t but it does not help. My application is that i require an output of a maximum of 10 volts and minumum of 9.6volts, my input is a 24 voltage lead acid battery. The circuit must be able to supply the required output voltage. And it must remain constant even as the input voltage is droping until the input voltage drops below the voltage required to supply that amount of output voltage. Please assist me in building this circuit with the correct components required and diagram.Thanks
Platforms
Content
