I've never replaced a capacitor on anything before.
I was given a non-working HP 17" LCD monitor a couple of days ago. It was manufactured in 2005. I plugged it in just to see what it what it would do and it powered up and showed a crisp clear image (hooked to a PC). But the screen went black after about 5 seconds or so. The power light remained solid green.
After reading an article online about how relatively easy some LCD repairs are, I took it apart and found 3 very slightly bulging caps, all 3 were identical, 680uf 25w. The only source of electronics I have within an almost hour drive of me is Radio Shack. The closest cap they had was 1000uf 33w.
I replaced them, hooked up the monitor and it's working. I left it on about 10 minutes and the monitor has a beautiful picture.
Is it OK to leave those 3 caps in it or should I get the exact caps that was in it and replace them again? (will have to order online)
Also, these 1000uf caps were a little bigger and one of them I could not flush mount against the board. If it's OK to leave the caps in, is it acceptable to have a cap not flush to the board?
Thank you to whoever took the time to read this and offer any suggestions.
