First steps with PIC16F819
Robbs
I've written/plagiarized the following, as my first attempt to do anything
with a microcontroller:
------------------------------------------------------begin code------
list p=16f819 ; list directive to define processor
#include <p16F819.inc> ; processor specific variable definitions
errorlevel -302 ; suppress message 302 from list file
__CONFIG _CP_OFF & _WRT_ENABLE_OFF & _CPD_OFF & _CCP1_RB2 & _DEBUG_OFF &
_LVP_OFF & _BODEN_OFF & _MCLR_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_IO
main
BANKSEL PORTA ; select bank of PORTA
CLRF PORTA ; Initialize PORTA by
; clearing ouput
; data latches
BANKSEL ADCON1 ; Select Bank of ADCON1
MOVLW 0x06 ; Configure all pins
MOVWF ADCON1 ; as digital inputs
MOVLW 0x00 ; Value used to
; inititalize data
; direction
MOVWF TRISA ; Set RA<7:0> as outputs
MOVLW 0xAA ; Output '10101010b' to
; PORTA (I hope)
; initialize eeprom locations
ORG 0x2100
DE 0x00, 0x01, 0x02, 0x03
END ; directive 'end of program'
-----------------------------------------------------------end
code-------------
Will this do what I hope it will, simply output 10101010b (0xAA) to PORTA?
If so, is it safe to check the pins with a voltmeter between the I/O pin and
Vss? would a series resistor be wise?
Thank you very much,
Robbs
Robbs
Funny how seeing your post in an actual ng can make you see errors. Sorry,
with corrections:
main
; clearing ouput
; data latches
; inititalize data
; direction
; PORTA (in theory)
ORG 0x2100
Robbs
Sorry. With corrections:
main
; clearing ouput
; data latches
BANKSEL TRISA ; Select Bank of TRISA
; inititalize data
; direction
MOVWF TRISA ; Actually write the
; value to the register
; PORTA (in theory)
MOVWF PORTA ; Set RA<7:0> as outputs
ORG 0x2100
------------------------------------------end code-----------
Is the last bit of code necessary, under 'initialize eeprom locations'? it
was part of the example code supplied with MPLABS, and I'm not sure exactly
what it does.
I realize that one pin on PORTA (pin 5, i think) is an input only.
Robbs
I
Ishaan Dalal
; clearing ouput
; data latches
; inititalize data
; direction
CLRF TRISA will do just as well.
; PORTA (in theory)
Code looks OK, comments are skewed -- MOVLW 0xAA moves the literal to the W
reg, while MOVWF PORTA actually outputs 0xAA to PORTA.
Yes.
Yes; no series resistor needed; but 8 LEDs with series resistors might be
easier to decode.
what it does.
Not for whatever your main code does.
Then that pin is permanently tri-stated -- you will see nothing on that pin,
unless you force it by using a pull-up or pull-down resistor.
L
Leon Heller
main
; clearing ouput
; data latches
; inititalize data
; direction
; PORTA (I hope)
ORG 0x2100
code-------------
It would be a good idea to end main with something like
stop:
goto stop
checking with a meter is OK, you don't need a resistor.
Leon
Michel Catudal
main
; clearing ouput
; data latches
; inititalize data
; direction
; PORTA (in theory)
ORG 0x2100
and Vss? would a series resistor be wise?
exactly what it does.
Robbs
Your program will do unexpected things after it crashes at the end of your code.
This is not a PC, you must provide some code to either rerun some of the same
code, some other code or do nothing. The way you wrote it, it will run whatever
garbage follows your code.
