Hi all,
I'm working on an audio design where I need to split frequencies, and I was wondering if instead of using two separate filters, could I simply use one RC high pass filter, connecting the node between capacitor and resistor to one Op-amp and the ground (other side of the resistor) to the input of another Op-amp.
Would this work? I assume that the high frequencies would go to the first Op-Amp, as it is at the "output" of the filter, and the low frequencies should go to "ground" which would be the input of the second Op-Amp. Am I correct?
Here's a text diagram, I don't have a schematic or anything to upload..
....R
---vvvv---o-----Input of OpAmp 1
...........= C
...........o-----Input of OpAmp 2
(Ignore the periods, I had to edit it to get the spacing correct again.)
Thanks!
....R
...........= C
Thanks!
