Finding the missing Resistor of a circuit
Hi i have two questions that i really need help with
i have a series diagram which is like this:
Vs = 24 V
R1 = 2 ohm
R2 = 4 ohm
R3 power = 24 W
what is the value of R3 resistor?
please if u can explain in details step by step it would be helpful thank you
2nd question :
R1 = 2ohm
R2 = 4 ohm
R3 power = 24 W
Is = 19 A
Vs = not given
thank you
davenn
hi, welcome to the forums
ok here's a great www site for working out voltages across resistors in series
you can use examples there to work out unknown battery voltage current in a cct etc
have a read and apply the formulas to your values and see how you go then ask a few more questions here on anything yoou dont understand :)
http://www.tpub.com/neets/book1/chapter3/1-12.htm
cheers
Dave
I would try the second one first. It seems to b a simple application of the appropriate formula that you should have on the tip of your tongue (involving power, current and resistance).
