Steven O.
I am taking a distance learning "lab" class in EE, using Multisim to
simulate circuits at home. Unfortunately, e-mail communications with
the professor sometimes does, and sometimes does not, result in clear
answers, so once again I'm going straight to the pros.
We are simulating a 741 OpAmp circuit as a low-pass filter. My
question is, what is the correct formula for the cutoff frequency? If
I understand correctly, the cutoff frequency is the frequency where
the output falls to 1/sqrt(2) = .707 of the input voltage. The
circuit is shown at:
http://www.oppenheimercommunications.com/OpAmpProblem.htm
The measured cut-off frequency is around 300 Hz (1884 radians). And,
using the formula for Vout (which I do have), and plugging in various
values for w_in, I eventually find the cutoff frequency to be almost
exactly 310 Hz (1947 radians).
The lab manual for the circuit does not give the formula. The
textbook has a similar-but-not-identical circuit, for which the
formula for the cutoff frequency is (referring to the diagram)
w_cutoff = 1 / (C2 * R4). However, this formula is not really for the
circuit we are simulating, and in fact does not give the correct
cut-off frequency.
Hunting on the Web, I found what seems to be an identical looking
circuit, and the cutoff frequency is given by:
w_cutoff = 1 /sqrt (R2 * R4 * C1 * C2)
Once again, however, this does not give the actual, measured value for
the cutoff frequency. Working from the formula for the output
voltage, I tried to find the formula for w_cutoff myself, but got lost
in a blizzard of algebra. If someone could tell me the correct
formula -- and better yet, steer me towards a derivation somewhere on
the Web -- that would be much appreciated.
FYI, the formula I arrived at for the output voltage is:
Vout = ( Vin / R2 ) / [ (R4/c1) * (1/R2 + 1/c2) + 1/c1 + 1/R2 ];
where cn = 1 / ( j * w * Cn )
(One other thing that would be useful -- if someone could take the
formulas above, and show me how to use Matlab to get the symbolic
result for w_cutoff. I got stumped on that one as well!)
Thanks in advance for all replies.
Steve O.
"Spying On The College Of Your Choice" -- How to pick the college that is the Best Match for a high school student's needs.
www.SpyingOnTheCollegeOfYourChoice.com
cut-off frequency.
Steve O.
