Don Lancaster
It is usually a fairly simple matter to get from a trig or exponantial
function of one sort or another to its underlying series form.
But how can you get from a known accurate series expression to a
nonobvious and crucially esoteric equivalent function?
Specifically, the "raw" power series
[-1517.83 5094.6 821.18 -29457.7 61718.9 -61268.8 30448.6 -4770.84
-269.684 -2892.14 3300.63 -1460.88 213.578 78.8959 -49.2164 12.3083
-1.74731 0.149743 -0.00245142 0.103691]
where 0.103691 is the x^1 term, -0.00245142 is x^2 etc...
The equivalent McLauran Series (or Taylor about zero) is found by
dividing each term by its factorial. 0.103691/1! , -0.00245142/2!...
... may be of extreme interest in finding a closed form expression
that involves trig products and possibly exponantials. The range of
interest is from 0 to 1.
The function appears continuous and monotonic with well behaved
derivatives. There is no zero offset.
The trig angle of 84.0000 degrees is also expected to play a major role
in the solution. As is the trig identity of cos(a+b) = cos(a)cos(b) -
sin(a)sin(b). As is a magic constant of 0.104528. Everything happens in
the first quadrant.
Sought after is a closed form determnistic solution that accepts the 0-1
value, the 84 degree angle, and the magic constant that evaluates to the
above series.
Many thanks,
Don Lancaster voice phone: (928)428-4073
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
rss: http://www.tinaja.com/whtnu.xml email: [email protected]
Please visit my GURU's LAIR web site at http://www.tinaja.com
the first quadrant.
above series.
Many thanks,
