I currently have a power supply capable of 250W output, with the output voltage adjustable from 5V to 1000V (yep, that would be 250mA at 1000V). I'm soon to get a similar power supply capable of 600W and 3000V.
These are deadly (I know that).
They are electrophoresis power supplies, and I picked them up for next to nothing.
A problem they have is that that are not well regulated, varying a bit with load, noisy, and with an output voltage that tends to wander. They have a few other issues, but filtering is the one I'm tackling at the moment.
3000V capacitors are not really an option. However I have plenty of 400V 100uF caps that I will place in series (10 in series).
Balancing the voltage across each of them is obviously important, and using resistors would be very wasteful of power.
My thought is to place 350V transient voltage suppressors (1.5ke350a) in parallel with the caps. At 300V they leak about 1uA, and they clamp at a voltage safe for the caps. Because they are basically a zener, they will also limit three reverse voltage across the caps when they discharge.
The problem is pretty obvious though -- whilst they're rated for 1500W, that's only for something like a millisecond. (Constant dissipation is something like 3W) The current through these devices will depend significantly on the variation between the capacitors, and I don't expect it to be very high.
Do you think it will work? Any alternate suggestions?
I plan on trying this with a lower voltage array first (for around 1kV) before scaling it up to the full 3kV.
10uF isn't a lot of filtering, but I plan to make a linear regulator to follow it.
