Phil Allison
Hi all,
the Fender " Super Twin " has to be my least favourite Fender model.
http://www.ampwares.com/schematics/super_twin_180w.pdf
This week, one came in that had been modified, butchered and totally
buggered.
The list of things wrong was staggering:
1. No AC fuse and foil inside the holder.
2. AC switch broken.
3. Standby switch broken.
4. OP tranny loose.
5. Two 6L6s visibly burnt on bases and glass.
6. Two 6L6s missing ( out of six ).
7. Two diodes in main bridge short circuit.
8. Bias filter electro open.
9. Bias feed resistors changed from 33k to 330 kohms.
10. Hum balance pot burnt out.
11. Negative feed back resistor changed from 820ohms to 1Mohm.
12. UL connection on 6L6 screens removed and new screen supply circuit
fitted badly.
13. All filter electros 36 years old.
14. Main filter electros 100uF each instead of specified 220uF each.
15. Chassis and cabinet dirty and speaker bolts all loose.
The only good thing and what made the amp worth doing was that the two 12
inch speakers were 75 watt Fanes in good condition.
...... Phil
buggered.
4. OP tranny loose.
fitted badly.
...... Phil
