Hi I am a hobbiest at electronics, I know enough to troubleshoot most minor problems but I have ran into a problem I can't seem to track down. I need help so anyone familiar with guitar amp repairs I would really appreciate some help. So here is a link to my amp
https://www.google.com/url?sa=t&sou...AQFjAC&usg=AFQjCNGQ6cCxuT1XLGULEnus3axV8HowUA
I received this amp with a large hum found the high voltage side filter caps were loose I resoldered and it played beautifully for about an hour then pop. I have replaced the transitors 10-13 and also the darlington transitors 15-19 15 and 14 were shorted so I replaced them all, also the filter caps on the high end........ The transistor shows the right voltage when I tested it. Here's what's happening. If I plug it directly into the wall it blows the 4amp fuse, I built a poor man's voltage limiter with a light bulb, when I run it through that the 300 Watt light lights up but I am able to play guitar through the amp with a loud 60hz hum. If I unplug the two red wires for the circuit (hi voltage end) the amp does not hum or pop fuse. Any help anyone could be I'd really appreciate it! Thanks for your time
