Doc
Have a Sony Digital8 and it appears the 1394 port has died. I have a 6
foot and 10 foot firewire cables. Never had a problem with the 6-foot
cable but the connection on the 10-foot has always been iffy - if it
got jostled the right way I lost the connection to the computer.
However because of where I needed the cam to be, the 6-foot connection
wasn't long enough. Upon close inspection of the ends on both, the
height of the contacts didn't seem exactly the same. So I did a little
light squeezing of the 10-foot cable's end with needlenose pliers to
adjust it a hair.
Plugged it into the 1394 port and got nothing no matter what. Then when
plugging in the previously dependable 6-foot cable, got nothing from
that either. Tried wiggling both at various angles to see if I could
establish any connection, get nothing on 2 different computers. So,
obviously something's wrong.
1) Any suggestions for remedies I might try on a DIY basis? An chance
it could be a mechanical physical contact issue and not an internal
fried chip/circuit issue?
2) Any idea what cost for such a repair would likely run? The problem
is, without a 1394 connection, the cam is kinda pointless. Yes, it has
analog out which works but the whole point of the Digital Cam is to be
able to create DV files.
3) Are the 1394 connectors generally fragile or are there brands with
ports that are more robust than others? What do you think I might have
done to cause this or was it possibly just a coincidence? I didn't poke
around the port on the cam at all, just tweaked the end of the one
cable a small amount.
Thanks for all input.
adjust it a hair.
