It's probably (definitely!) easier to breadboard.
John
Truly, the only way to properly "select" an inductor or transformer is
to experiment and characterize in the lab. I spent two years going over
a power supply for the med industry where a single turn more OR a single
turn less than the final number made a huge difference.. THEN simply
using Litz improved it further.
Rather than trying to model Litz, one should use standard models for
ordinary transformation. THEN use different Litz configurations and
FIND the best one for that form factor xformer and operating frequency.
There will ALWAYS be an improvement. THAT is all one needs to count
on. Put numbers to the standard, and KNOW that you will get better
performance from the change to Litz (even simple bi or tri filar yields
results). The inductor was the same way. The result is/was not merely
better performance, but the unit ran down to a lower drop out point on
the line side as a result as well. So it would work all the way down to
3.5 Volts when it used to drop out at 6 Volts.
