N_Cook
Small lighting unit and this powered speaker shared cheap and nasty plastic
multiway mains adaptor. Much crackles and bangs from bad contacts in the
adaptor but both survived working order . This amp had smoke coming from it,
at the time of the crackling. The bridge rectified 52-0-52V ac supply used
to have a cap across it, burnt up to just 2 pins now.
Only FBT schema, out there found, is for the MAX 9SA for which that
component is 100nF 200V , so replace with disc ceramic of that rating or
higher? or C +R ? and of course advice to obtain metal cased mains multiple
adaptor.
adaptor.
