Hi, I'm trying to fix a Dr Swamp dual distortion guitar pedal made by a Danish Company called T-Rex.. The circuit doesn't seem to be online but I have attached a schematic for another model they make that is similar (see the Mudhoney schematic image below).
The switching IC and flip flop circuit seem to be functioning fine - both channels light up when the relevent footswitches are depressed and also it switches to bypass no probs. However, the thing has lost a load of gain on both channels and so is not really clipping as it should. Its strange because each channel has its own separate pair of diodes for clipping the signal to create the distortion. They share the same amplifying IC (an OPA 2277 dual op amp something like this... https://www.ti.com/lit/ds/symlink/o...l-mousermode-dsf-pf-null-wwe&ts=1650312565053 (page 4)) but each channel uses a separate op amp on this ic - one side using pins 1,2,3 and the other 5,6,7. However, as I say, the lack of gain is identical on both channels.
Could the 2277 chip somehow have lost its gain on both channels? Is that possible?
DC Voltages on all pins seem correct (9V supply (battery)) plus around midway - 4.5v - on the +ve -ve and output pins.
Any help would be much appreciated!
CHeers
Tom, UK
CHeers
Tom, UK
