Anand said:
Hi Everybody,
Could someone please explain the use of a Fast Recovery Diode? I am
particularly interested in:
1. How is this diode different from a regular rectifier diode.
2. The role of these diodes in MOSFET circuits.
(Sorry, there is no Wiki for this.)
Thanks for your help.
Regards,
Anand
The difference is, a fast switching diode will become non conductive
a lot sooner than a non-fast switching diode.
In non fast recovery diodes, the path between the anode and cathode
is still some what conductive after the current that placed them in
that state is gone. What this means is, reverse polarity on this diode
will cause a conductive path in the reverse direction for a per scribed
amount of time just after a completion of a forward path on the diode
if not sufficient time given to have it recover before this reverse path
appears across the nodes of the diode.
It acts like a cap that has been charged and when reverse voltage
appears across it, it'll exert current. But don't get confused, it's
not the same thing. It's all about electrons and the way they impact
the surface of the materials between the anode and cathode used in the
diode. Fast diodes are made a little differently to limit this problem.
TO get a better understanding, look up Ultra Fast Diodes or Switching
diodes..
P.S.
Transistors of many kinds are also spec'ed this way.
