external firewire case died - can I buy a replacement 1394/ide bridgepcb?
H
hupjack
I've got an ADS Tech Pyro 1394 external firewire enclosure that appears
to be dead.
http://www.adstech.com/support/ProductSupport.asp?productId=API-800&productName=PYRO 1394 Drive Kit
Drives will spin up and down and up and down when connected and
firewired to a computer... the drives are known to be good..
(accessible when in other external cases)..
I'm assuming the 1394/IDE bridge died in some way..
trying to ID this PCB, the silk screening says..
1394/IDE Bridge PCB
REV 6.1-V (WA02040M)
I'm guess as long as the form factor is the same, and it accepts the
standard voltage, I wouldn't need an exact matching PCB.
Can these be purchased? Can somebody direct me to a vendor?
