Expro universal power adapter doesn't do 18.5V
1
123Jim
Hi all,
My second laptop power cable began to get flaky .. intermittently failing to
power/charge the laptop/battery.
I decided to get a replacement for it in the shape of an 'Expro Universal
Laptop AC Adapter'
My previous power brick is rated at 18.5V for 3.5A .. but this universal
power brick only does voltages in whole numbers: 12V, 15V, 16V 18V, 19V @
4.5A and 20V, 24V @ 3.75 Amps.
http://www.amazon.co.uk/gp/product/B003SQRKKG/ref=oss_product
Although .. it says: "covers between volatages also" on the above linked
page...
Which voltage should I choose, 18V or 19V?
What might be the problem for the Laptop since I can't choose 18.5V?
It seems to be working fine on 18V at the moment in initial testing.
Paul
123Jim said:
Hi all,
Laptop AC Adapter'
page...
Based purely on user experience (try and find a spec), laptops
*are* sensitive to the voltage delivered by the adapter. One
person had a failure after 30 days of using a "universal" adapter,
so some care must be used. If you feel more heat, coming from the
laptop power management area, that would be a sign you're feeding
it too much voltage. Or, if too little voltage, you might find the
battery never has a full charge on it.
If all systems are functional at 18V, and you're getting a full charge
on the battery, no further experiments are necessary. The allowed range
is down around +/- 1V or so, so you should do your level best, to match
the original spec if possible. The difference between 18.5 and 18.0 is
likely fine.
As one other poster indicated, verifying the voltage is a good idea,
since the new adapter will have a tolerance on the stated numbers,
and a setting of 18.0, may not be delivering 18.0 after all.
If you want to verify the voltage, that'll be harder to arrange. An
auto mechanic, would probably use sewing needles clamped to multimeter
probes, as a way to pierce the insulation on the wires and take a
reading. An engineer would likely prefer to use an adapter cable,
with perhaps a male and female barrel connector, so you'd get a
voltage sample safely. If the meter probes short together, while
you're taking your voltage reading, that could damage something.
(The adapter probably has overcurrent protection, but you never know.)
As far as I know, the laptop adapters are switching power supplies,
as a transformer/bridge rectifier/cap solution would be too heavy for
portable usage. Switching power supplies are much lighter by
comparison. A switching supply will deliver pure DC, and a
garden variety multimeter set to DC volts, is all you need
to check the output. There are two possible measurements
you can make - open circuit voltage from the adapter, or
check the voltage while the adapter is in usage.
The adapter regulates to the voltage "it can see" - if the adapter
had remote sensing (two sense wires that snake down to the load end),
it can compensate for the voltage drop in the cable under load. (ATX
power supplies use that method, but only typically on the 3.3V rail.)
If the adapter only checks the voltage as created inside the adapter,
then the adapter will have poor load regulation, and you'd see some
variation (no load vs full load), down at the connector end. The
voltage drop in the cable, gets subtracted from the regulated
voltage inside the adapter.
If you don't want to even think about the multimeter thing, no problem,
just continue to use the 18.0 setting.
Paul
Baron
123Jim Inscribed thus:
Hi all,
failing to power/charge the laptop/battery.
Universal Laptop AC Adapter'
universal power brick only does voltages in whole numbers: 12V, 15V,
16V 18V, 19V @
linked page...
The 18 volt setting will be fine. Most bricks are only a nominal voltage
+-5%. The only laptops that will care are the ones that look for the
ident from the power brick.
H
Herbert John \Jackie\ Gleason
On Wed, 15 Sep 2010 23:14:41 -0700 (PDT), I AM PROTEUS
snip
ASSWIPE YOU NEED A BULLET IN YOUR HEAD
OR A DEERS HORN UP YOUR ANUS
LEAVE STOP HARASSING ME AND THIS GROUP
IAP
snipped retarded stupid group abusing horseshit
THREAT ABUSE COMPLAINT! ABSOLUTELY ILLEGAL!
complaint forwarded to: [email protected]
Start looking over your shoulder, Roy.
1
123Jim
123Jim said:
Hi all,
Laptop AC Adapter'
page...
Thanks go to those who replied on topic
I used a multi-meter (and some soldering wire I happened to have handy)
...... it tells me the adapter is producing 18.51V ... so that'll do nicely!
