This is homework so no spoilers please!
The goal of the assignment is to create a program to guess your secret number from 0(inclusive)-100(not inclusive). I have made some headway, but I am having trouble creating a proper iteration that will collect the response and then based on the three possible scenarios of 'h' - high guess, 'l' - low guess (lowercase L) or c - correct guess do three different tasks.
If the guess is 'h' or 'l' I would need to iteratively guess by bisection search.
It's supposed to look like this in practice:
Is your secret number 91?
Enter 'h' to indicate the guess is too high. Enter 'l' to indicate the guess is too low. Enter 'c' to indicate I guessed correctly. y
Sorry, I did not understand your input.
Enter 'h' to indicate the guess is too high. Enter 'l' to indicate the guess is too low. Enter 'c' to indicate I guessed correctly. c
This is the code that I have produced so far - note the variables have not been cleaned up - as I started writing I tried one method and used some variables and tested other methods so the variables have grown.
As you can see I am having trouble with setting up the iteration. And handling the data structure. And passing the data back for processing... How should I approach this? Point me in the correct direction if you can or do I need to start from the ground up?
Thanks!!
Code:
choice = 0
guess = 50
win = 0
y = 100
hi = y
x = 0
lo = x
print 'Please think of a number between 0 and 100!'
print 'Is your secret number 50?'
while (win != 1):
choice = raw_input('Enter "h" to indicate the guess is too high. Enter "l" to indicate the guess is too low. Enter "c" /
to indicate I guessed correctly. ')
if choice == 'h':
guess = ((guess+lo)/2)+1
print guess
if choice == 'l':
guess = ((guess+hi)/2)-1
print guess
if choice == 'c':
print 'Game over. Your secret number was: ', guess
win += 1
break
if choice != 'h' or 'l' or 'c':
print 'Sorry, I did not understand your input.'
Thanks!!
