Hi all
I tried to etch my first PCB today, but it conducts at about 30k to 100kOhms between some tracks. Did I not leave it in the ferric chloride long enough, or is there some conductive residue left on the board. The process I went through was as follows.
1. I prototyped the circuit on a breadboard.
2. I drilled all the holes on the copper plated fibreglass.
3. Then I cleaned the copper with an eraser and methylated spirits.
4. Then I drew the tracks on the copper with a permanent marker.
5. Then I agitated the board in ferric chloride solution in a dish for 12 minutes, rubbing it gently with a toothbrush.
6. It looked fully etched, so I washed it with water and then with meths, and dried it.
7. I mounted the components, soldering them on.
8. Everything worked fine except a TSOP which was supposed to be giving a reading of 5V was reading all kinds of varying lower voltages on its data pin.
9. We discovered that the etched board was conducting a bit, between pins, with a resistance of 30k to hundreds of kiloOhms.
Can anyone explain what this slight conductivity might be? Did it not etch fully? I don't think I would have noticed the problem if I was not trying to read a remote's IR signal through the TSOP, which is very susceptible to some kind of external pulldown resistance.
I have never bothered to make a PCB because my soldering is sub-standard, and it often gloops pins together in one ball of solder. But I will say that my soldering improved manyfold after I took an angle grinder to the point of the soldering iron, turning it into a lean, mean soldering machine
If you could also recommend a program to draw circuits, which is a circuit simulator and then turns the circuit into a PCB, preferably for free, that would also be greatly appreciated.
