"John Larkin"
"Phil Allison"
** It is *unhelpful* because it is so damn ambiguous.
** It makes less sense to scorn a perfectly practical test method.
** The overwind is to be around the existing coil, wound in parallel and on
top of it, touching it - is that hard to comprehend ?
Not a bit. But the outer coil has - surprise! - a bigger diameter than
the inner, so more of the return flux is flowing *inside* the sense
coil, in the direction that reduces the induced voltage. Given a
typical drum/bobbin type inductor, I'd guess that the resulting error
might be in the 50% sort of turf; the actual error depends on the
geometry of the windings, and how close the sense winding can actually
get, given the insulation or epoxy or whatever cited.
A further ( rather obvious) condition is that the inductor coil current for
the test be low enough to not generate a significant voltage drop across the
coil's resistance - or you calculate that drop and take it into account.
Up to saturation - and an drum core will usually vaporize before it
saturates - the voltage ratio, whatever it is, will be independent of
drive level; the coupling is linear. A high drive *frequency* will
limimize the effects of copper loss, although it can be approximately
accounted for.
** I just took a small mains toroidal ( 30VA) and with the primary
energised at 230 volts passed a one turn loop through the core and measured
0.102 volts rms across the ends. The loop could be made as open as you
liked or tight wrapped as you liked with NO change in the measured voltage.
With a closed, high-permeability core, voltage ratios can track turns
ratios to a part per million, as in a precision AC ratio box. Since
virtually all the flux is concentrated in the steel, any loop of any
size pretty much slices the same amount of flux. A torroid is ideal
for close coupling. That's not the case with a system dominated by air
gap, because the flux is scattered all over in space.
The primary magnetising current was only 1.5 mA and the primary resistance
was 94 ohms - so a negligible primary drop of 140 mV.
So I make the primary turns to be 2255 ( +/- the AC voltmeter's 0.3 %
error, or about 7 turns)
Transformar manufacturers routinely use DVM-looking gadgets that
indicate turns ratio, and can easily and accurately resolve whole or
half turns. But only when leakage inductance is low, as for a closed,
high-mu core with tightly-coupled windings.
John
