Sir mrel . . . . .
ALL types . . . . BUT . . . . ESR is mainly being a problem emcountered with electrolytics .
Particularly ones that are subjected to high frequency or pulse related handling along with a parallel potential to run warmer, just by virtue of those conditions.
What few high capacitance non electrolytic capacitors I do have, of which the highest I have would be a 22 ufd mylar dielectric unit @ 50 working volts . . . .and many-many of cascaded lower values.
I will measure them and use them as " GOLD STANDARDS " . . . . to see if any electrolytic can even approach their low ESR values.
You just have to test-test-test and TEST several units to get the idea of average expected ESR values.
Plus, don't get thrown off if you come up against a 10 ufd @ 450VDC, since its inherently going to have a higher ESR than you had been accustomed to finding at lower working voltages.
If you want to prove something to yourself, test a high value cap for its ESR value and then take a 10 ohm resistor in series with the same cap and retest again.
Taking a 270 ufd capacitor at 25VDC you would find yourself having a mere 60ufd or so, actually being the equivalent capacitance then functioning in your circuit.
73's de Edd
