I have made the following program for a line follower, But it shows the following error for AVR studio. can you help me out?
Below is the program
/*Connect the Sensors to PortA Pin 0 (Rightmost Sensor) to Pin 4 (Leftmost Sensor)*/
#include<inttypes.h>
#include<avr/io.h>
#include<util/delay.h>
//#include"stepper.h"
/* Following are macros which are used for condition checking. Each macro check for a specific
condition. Read the operations properly to understand how they work. */
#define STLINE ((PINA&0x11)==0x11)&((PINA&0x1f)!=0x1f)
#define IDEAL ((PINA&0x1F)==0x1B)
#define LINELEFT ((PINA&0x1f)==0x03)|((PINA&0x1f)==0x07)
#define LINERIGHT ((PINA&0x1f)==0x1|((PINA&0x1f)==0x1c)
#define LEFT90 ((PINA&0x1f)==0x07)|((PINA&0x1f)==0x03)|((PINA&0x1 f)==0x01)
#define RIGHT90 ((PINA&0x1f)==0x1c)|((PINA&0x1f)==0x1|((PINA&0x1f)==0x10)
#define JUNC !(PINA&0x1f)
#define SPEED 30
void main(void)
unsigned char turn=0, s; //turn flag remembers the last turn taken. S is to count number of steps
DDRB = 0x0f;
DDRD = 0xf0;
DDRA = 0x00;
PORTA = 0xff; //Initialize motor and Sensor Port
while(1)
while(STLINE) //Follow Straight Line
if(IDEAL) //Ideal Condition
lstep_f(SPEED); //Go Straight
rstep_f(SPEED);
if(LINELEFT) //Turn Left
lstep_f(SPEED);
if(LINERIGHT) //Turn Right
rstep_f(SPEED);
if(LEFT90) //90 degree LEFT TURN
for(s=0;s<=3;s++) //Go 4 steps and recheck condition
lstep_f(SPEED);
rstep_f(SPEED);
if(LEFT90) // If condition is still LEFT90, do this
for(s=0;s<=20;s++) //Go Forward 21 Steps
lstep_f(SPEED);
rstep_f(SPEED);
for(s=0;s<=10;s++) //Diff Turn Left 11 Steps
lstep_f(SPEED);
rstep_r(SPEED);
while(!(IDEAL|LINELEFT|LINERIGHT)) //Diff turn Left until line is met
lstep_f(SPEED);
rstep_r(SPEED);
turn=0; //Set Turn Flag = Left (0)
if(RIGHT90) //90 degree RIGHT TURN
lstep_f(SPEED);
rstep_f(SPEED);
if(RIGHT90) // If condition is still Right90, do this
lstep_f(SPEED);
rstep_f(SPEED);
rstep_f(SPEED);
lstep_r(SPEED);
rstep_f(SPEED);
lstep_r(SPEED);
turn=1; //Set Turn Flag = Right (1)
if (JUNC) //If Junction is detected,
for(s=0;s<=20;s++) //Go straight 21 Steps
lstep_f(SPEED);
rstep_f(SPEED);
if (turn==1) //If last turn was right,
for(s=0;s<=10;s++) //11 Steps Diff Left
lstep_f(SPEED);
rstep_r(SPEED);
lstep_f(SPEED);
rstep_r(SPEED);
else //If last turn was Left
for(s=0;s<=20;s++) //11 Steps Diff Right
lstep_r(SPEED);
rstep_f(SPEED);
while(!(IDEAL|LINELEFT|LINERIGHT)) //Diff turn Right until line is met
rstep_f(SPEED);
lstep_r(SPEED);
Build started 28.1.2011 at 21:16:51
avr-gcc -mmcu=atmega16 -Wl,-Map=LineFollower.map LineFollower.o -o LineFollower.elf
C:/WinAVR/bin/../lib/gcc/avr/3.4.5/../../../../avr/lib/avr5/crtm16.o: In function `__vectors':
../../../../../avr-libc-1.4.3/crt1/gcrt1.S:51: undefined reference to `main'
make: *** [LineFollower.elf] Error 1
Build failed with 1 errors and 0 warnings...
#include<avr/io.h>
#define SPEED 30
void main(void)
DDRB = 0x0f;
DDRD = 0xf0;
DDRA = 0x00;
while(1)
rstep_f(SPEED);
lstep_f(SPEED);
rstep_f(SPEED);
lstep_f(SPEED);
rstep_f(SPEED);
lstep_f(SPEED);
rstep_f(SPEED);
lstep_f(SPEED);
rstep_r(SPEED);
lstep_f(SPEED);
rstep_r(SPEED);
lstep_f(SPEED);
rstep_f(SPEED);
lstep_f(SPEED);
rstep_f(SPEED);
rstep_f(SPEED);
lstep_r(SPEED);
rstep_f(SPEED);
lstep_r(SPEED);
lstep_f(SPEED);
rstep_f(SPEED);
lstep_f(SPEED);
rstep_r(SPEED);
lstep_f(SPEED);
rstep_r(SPEED);
lstep_r(SPEED);
rstep_f(SPEED);
rstep_f(SPEED);
lstep_r(SPEED);
