Bart
I have a controller that can control a servo motor amplifier. I can load
programs to it thru RS232 and run them but if I turn the controller off the
program disappears. The controller has a "Burn" command that will save the
program to an internal eprom chip and then if I turn off the controller and
then back on, the program is still there. My problem is I can't download
from the controller to my laptop so any programs I've loaded and run, and
edited and run some more, and edited till the program runs perfect....I
can't make a backup copy of it. I've opened the controller and there's no
battery inside, so could I remove the eprom from the controller and put it
in my eprom burner and download the file directly from the chip? And then if
I put the chip back in the controller the program will still be there to
run? Sorry I don't have the numbers off the chip 'cause I'm at home dwelling
on this problem.
Any advice is appreciated,
Bart
on this problem.
Bart
