Hi folks,
First post here. I am working on designing a circuit board and aluminum enclosure for a lab equipment type application. I have an mains-to-12VDC enclosed AC/DC module as my primary power supply. The rest of the board runs off the 12V or cascaded supplies. As the output to the UUT needs to be isolated from earth ground (think isolated power supply), DC ground is isolated from earth ground. My questions:
E
- For safety reasons, It is my intuition that the aluminum enclosure should be earth grounded. Is that correct?
- In IEC Terminology, I believe the bulk of my board (12V and onwards) is considered an unearthed SELV circuit. I am maintaining reinforced isolation per IEC-60950. Assuming the enclosure is earth grounded, then I must also maintain this spacing with respect to any SELV component and the enclosure, correct?
- In interest of a small form factor, I have clearances between components and the enclosure of less than the 4.0mm reinforced spacing required by the IEC standard. What would convention suggest here -- is robust dielectric tape sufficient to satisfy insulation requirements?
E
