Devendra
Hello All,
I am designing a controller based on 24VDC supply voltage. It is a
process indicator based on a Freescale 16 bit controller and
communicates with external devices using CAN or RS485.
I want to subject the product to CE testing.
I just want to know that whether the X and Y suppression capacitors
will be required for a 24VDC powered controller also!? I have put
across the line (X) capacitors as 0.1uF and 0.01uF.
Also whether my circuit ground should be isolated from the chassis
ground, because my unit will be subjected to some tests in which the
transient voltages are applied between supply lines (230Vac, 50Hz) and
Earth (connected to Chassis of my controller).
Kindly let me know your suggestions about standard design practices,
for EMI EMC compliance.
Thanks in advance.
Best Regards,
Devendra Jogdeo
Thanks in advance.
Best Regards,
Devendra Jogdeo
