L
Lenny
This post is partly a message which I posted the other day, however
now the problem has gotten more serious.
I'm running a 386/25 with Dos 6.2 for billing. The unit has two
Seagate MFM 40Meg drives that are doublespaced. It uses Qemm as a
manager, and the high memory area is being used. I use "Optimize" to
configure the memory. Scandisk found a problem on the E drive that it
can't fix and I hesitate to use Norton as this could make things
worse. Recently it has been having problems with bad sectors on the
drive showing, and refusing to boot unless you boot off a floppy and
do a sys c: from the A drive. Of course if you boot off the floppy and
then try to access programs they will either not run properly or there
isn't enough memory to operate them possibly due to doublespace not
loading? Anyway, now it will only boot if I'm lucky. Luckily I copied
my customer files on two floppies last time I got it to boot. But
there is alot of other stuff I would like to get off it. We are going
to try to get it to boot one more time and if it does I should assume
that it may be the last time. So if we're sucessful, I would like to
be ready to transfer everything on it to another drive. Is it possible
to do some kind of a transfer perhaps through the parallel port to a
Windows 2000 machine. We also have an old hard card which in theory
could be installed and it would boot my machine, but this other stuff
that presently has to load to make my machine come up and run properly
has me perplexed. If I can get in with my hard card is my data
accessible without doublespace being invoked? Of course
I would rather just get it to boot normally one more time and then do
some kind of a complete transfer. If anyone has any suggestions about
this I would be extemely grateful. Whew, I miss carbon paper. It never
crashed... Thanks, Lenny Stein, Barlen Electronics.
