Eliminating Turn off Losses in IGBTs... UPDATED
G
Genome
Eeyore said:
I like the idea.
Have you tried it ?
Graham
I'm too busy drinking my incapacity benefit.
Thanks for paying your taxes.
DNA
Mike Monett
Genome said:
Like I said before.....
Here you go.....
http://www.genomerics.org/patent/patent.html
Not finished yet, but it's a start.
You will say 'Gosh!'
It's an explanation of my crap patent explanation
http://www.genomerics.org/patent/final.pdf
Who's the bloke from Viet Nam who's been having problems downloading that
one? There have been 476 attempts of which 318 have been from one IP.
DNA
But now there is the PFC part as an example added.
DNA
Hi Genome,
This looks like a very interesting concept. Reducing losses by 75% is an
impressive accomplishment.
I'd like to run the LTspice model, but it needs your irgp50b60pmod.spi
file. When I try to download it, I get the following error message:
Forbidden
You don't have permission to access /patent/irgp50b60pmod.spi on
this server.
Apache/1.3.33 Server at www.genomerics.org Port 80
Can you change that so your fans can download the file?
Regards,
Mike Monett
Antiviral, Antibacterial Silver Solution:
http://silversol.freewebpage.org/index.htm
SPICE Analysis of Crystal Oscillators:
http://silversol.freewebpage.org/spice/xtal/clapp.htm
Noise-Rejecting Wideband Sampler:
http://www3.sympatico.ca/add.automation/sampler/intro.htm
G
Genome
Forbidden
this server.
Regards,
Mike Monett
That's a bit of a bum.... I had a look and, being thick, not only does it
not like me either but it seems to hate me.
Here's the text version....
I will try and work things out otherwise.
..SUBCKT irgp50b60pd1 1 2 3
* SPICE3 MODEL WITH THERMAL RC NETWORK
* Model Generated by MODPEX *
*Copyright(c) Symmetry Design Systems*
* All Rights Reserved *
* UNPUBLISHED LICENSED SOFTWARE *
* Contains Proprietary Information *
* Which is The Property of *
* SYMMETRY OR ITS LICENSORS *
*Commercial Use or Resale Restricted *
* by Symmetry License Agreement *
*Model generated on Jun 7, 04
* MODEL FORMAT: SPICE3
*Symmetry IGBT Model (Version 1.0)
*External Node Designations
*Node 1 -> a
*Node 2 -> g
*Node 3 -> k
M1 9 6 8 8 MSUB L=100u W=100u
..MODEL MSUB NMOS LEVEL=1
+VTO=5.14841 KP=4.6111 LAMBDA=0 CGSO=3.92729e-05
RD 7 9 0.000923964
RS 4 8 0.00104286
*D1 3 1 50b60pd1
*.MODEL 50b60pd1 d
*+IS=1.45652e-10 RS=0.0257735 N=2 EG=0.600503
*+XTI=0.5 BV=600 IBV=0.00025 CJO=2.89747e-10
*+VJ=0.4 M=0.430499 FC=0.5 TT=1e-09
*+KF=0 AF=1
Q1 4 7 1 QSUB OFF
..MODEL QSUB PNP
+IS=3.21641e-16 BF=40.1409 NF=1.22694 VAF=443.169
+IKF=2586.69 ISE=9.8821e-12 NE=2.21576 BR=0.990766
+NR=1.44702 VAR=123.998 IKR=999.935 ISC=1.00646e-11
+NC=1.99793 RB=0.534983 IRB=487.231 RBM=1e-05
+RE=1e-08 RC=0.00102494 XTB=0 XTI=2.99904
+EG=1.13276 CJC=1.4649e-09 VJC=0.4 MJC=0.353063
+CJE=1.4649e-08 VJE=0.4 MJE=0.2 TF=9.99991e-10
RDS 7 4 1e8
RER 4 3 0.00993049
RG 6 2 2.86055
RL 10 11 1
D2 12 11 DCAP
* Default values used in DCAP:
* RS=0 EG=1.11 XTI=3.0 TT=0
* BV=infinite IBV=1mA
..MODEL DCAP D IS=1e-32 N=50
+CJO=1.5982e-09 VJ=0.4 M=0.716994 FC=0
D3 0 11 DL
* Default values used in DL:
* EG=1.11 XTI=3.0 TT=0 CJO=0
* RS=0 BV=infinite IBV=1mA
..MODEL DL D IS=1e-10 N=0.4
VFI2 12 0 0
FI2 6 7 VFI2 -1
EV 10 0 7 6 1
CAP 10 13 6.40436e-09
RCAP 10 14 1
D4 0 14 DL
VFI1 13 14 0
FI1 6 7 VFI1 -1
..ENDS irgp50b60pd1
*SPICE 2-Layer Thermal Model Subcircuit
..SUBCKT irgp50b60pd1_igbtt 2 0
R_RTHERM1 2 1 0.157214
C_CTHERM1 2 0 0.002201
R_RTHERM2 1 0 0.163184
C_CTHERM2 1 0 26.22805
..ENDS irgp50b60pd1_igbtt
*SPICE 3-Layer Thermal Model Subcircuit
..SUBCKT irgp50b60pd1_diodet 3 0
R_RTHERM1 3 2 0.3601412
C_CTHERM1 3 0 0.000311
R_RTHERM2 2 1 0.8647836
C_CTHERM2 2 0 0.0013691
R_RTHERM3 1 0 0.473519
C_CTHERM3 1 0 0.0681324
..ENDS irgp50b60pd1_diodet
Mike Monett
it not like me either but it seems to hate me.
That's great! Thanks.
Regards,
Mike Monett
Mike Monett
RatsRatsRatsRats!
I made a self-inflicted injury. I downloaded your page using HTtrack, and
always tell it up to rename the files to the DOS 8+3 format. So your
irgp50b60pd becomes irgp50b6, and I had to rename all the include
statements in the LTspice files.
But that sure messes everything up! Now it can't find the subckt, and
probably a bunch of other things got screwed up also.
Moral of the story - not sure yet. This may take a while to sort out.
Regards,
Mike Monett
G
Genome
Regards,
Mike Monett
Whoops.... fixed it.
My html referred to the wrong directory so the server did a no-no.
I think I've fixed it...... can you give it a quick go?
Many thanks for the slap.
DNA
Mike Monett
That's even better. Now I can tell HTtrack to leave the filenames alone,
and forget about trying to fix my DOS 8+3 blunder.
Thanks, Genome!
Regards,
Mike Monett
G
Genome
Thanks, Genome!
Regards,
Mike Monett
Oh... good.
Once again thanks for checking. I don't think anyone else has bothered with
the simulation files but it would have been a little bit annoying if they
couldn't get hold of the model required.
And thanks for the HTtrack idea.... Good stuff, I ripped a couple of my
favourite specialist fetish websites and got all the piccies.
http://www.httrack.com/
Monster!
Hmmmm, now how do I set this thing up for....
http://www.bbcd.de/menue.html
DNA
Mike Monett
Oh... good.
with the simulation files but it would have been a little bit annoying
if they couldn't get hold of the model required.
my favourite specialist fetish websites and got all the piccies.
Monster!
DNA
Thanks Genome. LTspice now works fine!
If you want to download the entire boot site, load HTtrack then load the
HTtrack.opt file.
Tell it where you want to put the download directory, and enter the url.
Next, press the "Set Options" button.
In the "Scan Rules" tab, click the images box and ensure the text area
shows "+*.gif +*.jpg +*.png +*.tif +*.bmp". If there are multimedia files,
then click the "mov..." box also.
This tells HTtrack it can go anywhere on the web to retrieve those files.
But do not tell it to download "htm", "html", etc. files. If the web site
references those files on a different web site, HTtrack will go there and
get them. They may themselves reference an unlimited number of files in
other directories, so you may end up trying to download hundreds of
gigabytes.
In the "Limits" tab, set the maximum mirroring depth to 20. That should
ensure you get pages that are way deep in directories.
In the "Build" tab, tell it the folder structure you want, and tell it "no
external pages". This keeps it from wandering all over the web and
downloading everything in sight.
In the "Mime Types" tab, ensure all entries are erased. Those are left over
from previous releases, and HTtrack now figures out everything internally.
But if you put anything in those fields, HTtrack gets confused and will
probably ignore those file types.
I think I got most of the critical things, but go through the rest of the
tabs and try to set them to your preferences. Then save your settings for
the next time.
Now you can press "OK" and proceed to download your web site.
Good luck, and let me know if everything worked OK.
Regards,
Mike Monett
Mike Monett
I forgot two of the most important things:
In the "Experts Only" tab, set "Travel Mode" to "Can Go Down".
Set "Global Travel Mode" to "Stay on the same address".
Now, it can only get html files in the current and child folders, but can
go anywhere to get the images.
You need to do this to prevent HTtrack from trying to download the entire
web. But you also have to give it permission to go upstream or to other
sites if necessary to retrieve the image files.
Regards,
Mike Monett
G
Genome
HTtrack.opt file.
Regards,
Mike Monett
Don't get me wrong here but I think the right answer might have been....
'Fiddle about with it until it works.'
Which is the right answer for fiddleable software....
I might have to practice on
http://www.regenmantel.de
She is just too Deirdre Barlow!
I'd have a bash at
http://www.kunzmann.com
But they have too many piccies of blokes in rubber.
What's that all about then? Why does a woman in fine latex look nice whereas
a bloke looks like a prat.
Oooops, bugger.
I don't know you.
DNA
Martine Riddle
I'm not from Nam, but I can't seem to be able to download it.
I'm on verizon.
Cheers
Mike Monett
I'm on verizon.
Sometimes I can't reach sites for unknown reasons, but going through a
proxy solves the problem. Try entering the url in
http://anonymouse.org/anonwww.html
Regards,
Mike Monett
E
Eeyore
And you choose to publicise this fact ?
Graham
