DaveC
I want to turn up a switching power supply slowly after repairing it, so as
to see if anything else is damaged. I have no Variac, and I could use the
series light bulb trick, but I already have a light dimmer I'm using as a
variable-temperature control for my soldering iron that could do double-duty
in this application.
I know that the SMPS, when running correctly, will be a load pulse at 75 kHx.
Has anyone tried using a dimmer as an "electronic variac"? Is it feasible?
Thanks,
Thanks,
