The bulb in my fridge-freezer exploded. I carefully removed the metal screw remains after unplugging the fridge. Replaced the bulb but it still would not light up after plugging back in. I tested with a meter and there appears to be a voltage of 230V across the terminals. I turned off again and gently adjusted the copper terminals thinking that it was a matter of non-contact with the bulb end. Again the bulb which I tested separately still does not light when screwed in.
There is a component in series with one of the leads leading to the socket into which the bulb is screwed. It looks as though it is somewhat burned. It has these letters and numbers written on it: Q89L 55C 11888.
Can anyone help me solve this puzzle? Why won't the bulb light up if there is the correct voltage, good contact and a good bulb? Is it inadequate current due to the damaged unidentifiable component? What could this component be?
If it helps the fridge freezer is a Westpoint BKF 405.
