Sir bazz . . . . .
I think that your problem possibly/ could have been related to the water, even though the unit is well waterproofed with an encapsulating covering. Looking as if possibly having used one
TOUGH two part low viscosity encapsulant such as the Scotch #300 series.
HOWEVER . . .you do see the white powdery lime/calcium family deposits on the top and bottom in the YELLOW boxed area.
On the top terminals, you do see the verdegris deposits, which take a time to grow, this just was not overnite.
ALSO I think that you just had a big dried drop . . . a long time ago . . . of that encapsulate being the blob that you mention and see on the transistor. See a similar s p r e a d out drop on the ferrite dumbell inductor nearby.
After my reading the boards foil, I’ll just bet that is going to be an NPN transistor as that oscillator and probably using a 12 / 24V derived supply.
The most noticeable thing is that solder whisker / splash that seems to be right between the SCR’s Anode and gate.
In the RED CIRCLE
Why don’t you do this?
Check out that pulled transistor and I am expecting it to be good and you finding ~600-800 mv Vf between its two Base to Emitter and Base to collector junctions, with its center terminal being its collector.
I can’t see other components on the back side with your pics coverage.
Clean the board of its top side and bottom side white deposits . . . the verdegris . . . can be done later on.
Reinstall the transistor
Use a DVM . . . due to its minimal circit loading . . . and put in ~ 500 VDC volts range and make connection to any point on the PCB foil pattern that covers most of the outer periphery of the whole board.
( See my negative terminal markup of the storage capacitor.)
If lucky . . . . . that caps max voltage spec might be marked somewhere upon its case.
The meter positive lead will TEMPORARILY go to the + terminal of that capacitor.
Scrape for connections to be made thru the encapsulant at your chosen test points.
Power up the unit and initially take a quick reading after ~ 5 seconds with your meters + probe then touched to the storage caps +, if the oscillator is working you should then see a DC voltage building up.
Take your probe away to preclude any loading, then wait another 10 seconds and see if the voltage is then greater.
If all is well, that voltage will store up and rise in level and trigger the spark / ignition coil.
Your pic did not permit viewing to see the additional components and their arrangements on the rear ledge.
I feel that the full storage capacitor voltage is going to the primary of the spark coil with its other terminal going to the anode of the SCR.
Its associated NE-2 lamp is its triggering device, and probably has a voltage divider pair of resistors associated with it so that there will be a higher voltage developed to dump into the spark coil primary.
If so, there may be upwards of 100-200 VDC on that storage capacitor being built up, while the voltage divider bridge is only feeding 1/3 of that voltage to the NE-2 trigger circuitry.
However it may be, when that NE-2 lamp detects in the 55-65 VDC across its terminals . . .being at its particular critical ionization and flashover threshold, the tube makes an orange blink and that voltage feed thru is connected to the gate of the SCR and it fully conducts anode to cathode.
( If the cap voltage is building up and you are in a subdued lighting, you could just slip a black tube over the NE-2 envelope sides and wait to see its flash from its top. )
That SCR connectivity dumps the full charge of the storage capacitor into the primary of the spark coil and a short duration high voltage spark level is created at that units secondary. (RED marked . . . . HV.)
If that solder whisker was present at your initial time of testing . . . that could have stopped all
Fill us in . . . . . .
BOARD MARKUP:
73’s de Edd
