AC is dangerous...I don't like it.
The fact that it's AC doesn't make it dangerous.
It depends on the power in Watts. If a kitchen oven is under load (turned up high for example), touching the wrong cables would probably be fatal because of the higher current draw x standard voltage. Slightly less dangerous if not under load...but still eye widening.
I agree. Remove the human from the circuit and the risk of electrocution is greatly diminished.![]()
But I get your point. The greatest danger is when high power cables cause thermal damage that breaks the skin and get inside the body cavity (which is largely fluid). Terminal.
Your explanation would be better if you replaced the term "power" in your post with "voltage"
