With internet and people who made the same projects I saw that they were having some results with capacitor of 300uf max so I hope I could get minumum the same result than them, but my problems right now are the inductor that I cannot find/make.
But were they generating EMP? I guess it's somewhat an issue of semantics.
What did you discover when you looked for a definition of EMP?
With the help of my physics teacher I already made a bobine that let me restart (sometimes if I'm lucky) an old half broken DS or to make an old calculator bug (writting random things and other).
What is a "bobine"?
For the protection, actually my project doesn't have a radius bigger than 20cm
How are you keeping the effect within this radius?
Only apologize if you're not using it.
if with another inductor I get a bigger radius, I'll have to make all the experiment at home and project the video during the science fair, I've already talked with the teacher that organize the sceince fair about the security measure.
What effect do you think a greater radius has (I assume you're talking about the radius of the coil)?
Yeah, I'd like you your help for this, I have 2 capacitor in parallel, so with a total of 2400uf and 350v AC
Are you sure they're rated for 350VAC? How big are they?
I'm wondering which type of inductor I should choose to have an external magnetic field, powerful enough to have something I could present.
Have you researched what determines the strength of the magnetic field?
And I'm wondering about something, the more Henry there is in a inductor, the powerful the magnectif field will be
That's not necessarily true
but if there's too much Henry on the inductor and not enough energy, wouldn't I have a really small magnetic field or not? I'm a bit lost on this, I hope you could help me, thank you Steve
Yep, you're lost.
One thing is the measurement unit Henry. It's a unit, like the metre. Saying you have too much Henry on the inductor is like saying you have too many metre on a string.
A string can be too long, and a coil can have too much inductance. Length is measured in metres, inductance in Henries. And 1H is a *HUGE* amount of inductance for most practical purposes. Typically it's like measuring your height in kilometres.
What you need to do is to figure out how the construction of a coil influences the magnetic field.
Then you need to consider whether you want a static magnetic field or something different.
Then you need to look at what happens when you discharge a capacitor into a an inductance. Is there any way of determining how this might affect the generated magnetic field?
Then you need to determine what combination of capacitance, voltage, inductance, and coil construction are going to give you the best effect.
Finally, you should research Faraday cages and build one around your project. Even if it turns out to be just for show, it will make people feel a lot safer approaching it with the fairly ubiquitous electronic devices that exist today.
Here is a quote for you:
A wise person said:
There is so much "hysterical crap" floating around about EMP and EMP mitigation that it is impossible to undo, so I generally stay out of it. Nearly all of the things I've seen on Internet cannot be more nicely described than being horse-droppings. This is especially true with devices to generate pulses
