Hi All,
I have a 27V DC going to a light indicator and somehow there is a leakage....when the controller sends a signal the light indicator comes ON which is great but when I measured the voltage when the indicator was off, it gives me a value of 12 volt which should be 0V...
The current is 20m A.....its not a safety concern but i want to know if there is any way I can use a voltage regulator or something so that whenever the voltage is more then 24V DC it will go through the regulator and turn ON the indicator and if it is less then 24V DC,the regulator will not output the voltage? any help is appreciated!
Thanks,
Thanks,
