E
Eric Smith
Does anyone have the electrical specifications for an SD5101 quad FET,
which is packaged in a 14-pin DIP? Nine of these are used on the DEC
M8018 writable control store module for an LSI-11, to interface between
the MOS-level microinstruction bus and the TTL-level logic and memory on
the module.
I'm not sure of the manufacturer of the part, though it might be
Siliconix or Calogic. From the schematic, it appears to be a quad
N-channel enhancement mode FET, with the pinout:
drain gate
FET 1 1 3
FET 2 7 5
FET 3 8 10
FET 4 14 12
common source, pin 4
common substrate, pin 11
Thanks!
Eric
[If you want to send a reply by private email, please remove the
obvious spam-proofing from my email address.]
the module.
drain gate
FET 1 1 3
FET 2 7 5
FET 3 8 10
FET 4 14 12
Thanks!
Eric
