If it's sealed, even if you can fix it, you may have a hard time sealing it again.
If the problem is water leaking into it, the damage may be hard to repair (if you shake it can you hear liquid inside?)
If it's just a failed battery you might be able to replace it.
It's also possible that the charger or the charging circuit has failed.
