Electret condenser microphone questions
Andrew Howard
I have a circuit for an ECM preamp but the microphone in the circuit has
three pins. The only types I can get hold of are the 2 pin variety. Is there
an easy way to convert the circuit so that I can use a 2 pin electret?
Andrew Howard
tempus fugit
Where is the schem? I think that the 3 pin variety has 1 pin for ground, 1
for signal, and 1 for V+. The 2 pin kind has 1 for ground, and the signal
and V+ is shared by the 2nd pin. The signal output must use a DC blocking
cap between it and the amp in.
tempus fugit
All you have to do is use a blocking cap from the output of the mic to
prevent sending the DC supply voltage to the preamp. The schematic you've
pointed to has a 10uF cap between the output of the mic and the base of the
transistor, so that will do the job. So, the only adjustment that you need
to make is to connect the 1K resistor to the same mic pin as the 10uF cap.
IOW, connect the top pin of the mic in the schem to the middle pin, and that
will be the same as the 2 pin ecm that you have. Make sure that the cap is
on the transistor side of the resistor, though, so it blocks the DC (like it
is in the schem).
One caveat - I notice the whole thing is powered by a 12v supply. Most of
these types of ecms recommend a 2-10v supply voltage (oddly, it even says so
in the article). You may want to either use a regulator to drop the mic
supply voltage down to 9v, or use a simple voltage divider. Keep in mind
though, that the 1k resistor effectively sets the output Z; this will change
if you use either the regulator or the divider method.
One other thought - these ECMs can be had very cheap (I'm asuming you're not
using an expensive element here) so you might want to just go ahead and try
it with 12v, and see if it works OK. Where are you getting your mic element
from?
Rob
Simply conect the 1k resistor to the 10uF cap. Connect the 'ground' of
the mic to ground of the circuit and connect the second pin of the mic
to the junction of the 1k resistor and 10uF cap.
Andrew Howard
I am getting the microphones from Jaycar, an electronics store in Sydney,
Australia. They cost about three Australian dollars.
By the way, thanks for helping me out with this problem with your quick
responses.
