I'm trying to whip up an EGT(Exhaust Gas Temp) warning light for a vehicle I own. Nobody sells a simple warning light and I don't need another gauge in the car. The probe (Thermocoupler) used reads in thermoelectric milivolts. I want to turn on an led in the dash when it reaches 1300 degrees F which is roughly 29.-30mV. I've put a lot of thought into this only to realize I am a complete noob and can not figure out how to set this up.
I've thought about using a thermocouple amplifier with a resistor and transistor but i guess I fail to understand the comple workings.
I'd ultimately like to power the LED via 14V (Battery) source and thought about a series of transistors used as switches could work. A problem I am facing is the power supply via EGT probe is completely independent.
The Probe has one red(Ground) and one yellow(Power) sending in mV from 0-40mV
Battery is 12-14.5V and I will be obtaining power via 5 amp fuse in fuse box
Help Please??
(If it helps, they sell EGT thermocoupler amplifiers to step up the mV output into a 0-5V using the vehicles Battery. If it is recommended to make this project possible, the 1300 degree F warning would be sent as 3V.)
Help Please??
