Jamie
We have a project at work that has been doing well for some time now,
and that is an Eddy/(foucault)current method of detecting surface
defects and cracks in copper conductor.. This includes stranded and
solid.. I guess it works for Tungsten, AL, and nickel, too!
There is going to be some changes made in the processing of the material
and I was asked, if it would be possible to submerge the coils in the
coolant water. I didn't give them an answer, still thinking about this..
We can protect the coils from water how ever, we use recycled water
for cooling and its not drinkable but on the other hand, does come out
clean looking, due to our filtration system.. Was wondering if any one
could shed some light on the effects I should be seeing when I place the
detector coils in the water? We do add a chemical to the water because
it's too hard from what I understand..
I guess the problem is, they need more coolant time and need the
space the detector is using, inline.. So the solution would be to have
this device in the water where the wire will be passing through.. This
test can also detect the sudden lose of insulation due do the Eddy
currents generating a phase shift. So, the thought of water around the
area tells me that this part of the test maybe ignored?
We do have a unit that measures wall thickness that uses eddy currents
how ever, that is not designed to be submerged in water..
Any comments on this would be appreciated..
Jamie..
Jamie..
