Hello
I'm new to Eagle and designing PCB's, but I have made my first design and have found good tips around here.
One thing I'm still not sure about is holes in Eagle.
If I make a hole with the hole tool, will there still be a soldering area around it? I have a 0,6mm line and 0,6mm hole, but on the design it doesn't look like there is anything around the hole.
Should I instead make holes with via's? I read somewhere that that would give a better area around the hole.
Is a via always connected from top to bottom layer or do I have to make my own connections after I receive the pcb? I'm thinking about letting a company make the boards for me because I don't need that many and don't want the mess with making them.
Thanks, I hope you can help me a little so I can finish my board.
