Hi, my 10 year old Dyson DC24 vacuum cleaner's brush roller stopped working during use. No burning or noises were reported. Upon inspection I found nothing visibly untoward. However there is no power output to the DC motor from the PCB which takes in 240 VAC and outputs DC of unknown voltage (a newer model has a 300 VDC motor). The PCB appears to have an open circuit 1 ohm resistor (R1 on the images, R4 on the diagram) which I think is a problem, hopefully the problem. There are no visible signs of damage. Note there is a safety switch activated by over loading the motor (I think) which I've not included in the circuit diagram for simplicity of drawing, it seems to be working OK.
I have a few questions about this circuit design:
1. What is the point of the 1 ohm resistor?
2. Why are there 3 equal value resistors in series?
3. What does the capacitor do?
4. What is the likely cause of this resistor being open circuit?
Thank you.
Thank you.
