Dynamo Air Hockey Table Need help with main board
I have a dynamo air hockey table from 1987. The score isn't working anymore and the game shuts off after a few minutes playing. I was told I probably need a board. However it's $300. Does anyone know of a person/company that can fix the board? The 2nd question would be does anyone know where I can get the main controller board pcb v7.0 cheaper then $300. I was hoping to keep it under $150. Thanks for any help.
Hey roastedrick, are you still seeking for the company which can provide you board. So you muct check out https://airhockeytablereviews.com/ and you get all answers regarding your air hockey table.
Sir roastedrick . . . . .
It looks like Valley and Dynamo are wed and now sleeping in the same bed . . . so look at these supplied links and see if it shows electro / mechanical similarities to your unit . . . .
My most significant observation is the use of a hefty storage battery to be able to play keep up on current demands.
You may have lucked out and are only having a power supply failure issue . . . . otherwise . .. they "own you" on a bad main board or any info on it .
Plus that price is not outrageous, if you had initially paid 5K for a unit .
Otherwise, if you fould it as a freebie . . . . you are are falling into the category of being a beggar . . . and beggars can't be choosey.
http://valley-dynamoparts.com/dynamo_schemas.asp
http://valley-dynamoparts.com/docs/2016BlackHoleHockeyManualFINALREVISION.pdf
https://www.betsonparts.com/downloads/dl/file/id/49/hockey_wiring_diagram.pdf
https://www.betsonparts.com/downloads/dl/file/id/47/hockey_logic_version_7.pdf
https://www.betsonparts.com/downloads/dl/file/id/51/hot_flash_overhead_installation.pdf
https://www.betsonparts.com/downloads/dl/file/id/52/photon_overhead_installation.pdf
https://www.betsonparts.com/downloads/dl/file/id/48/hockey_logic_version_6.pdf
https://www.betsonparts.com/downloads/dl/file/id/46/hockey_display_overhead.pdf
https://www.betsonparts.com/downloads/dl/file/id/45/display_side_schematic.pdf
Do any of these relate to your unit . . . . . , since you didn't further identify its specific model ?
73's de Edd . . . . .
If a stealth bomber crashes in a forest, will it make a sound ?
I have a similar question. I’ve got a shuffle board that has a scoreboard that no longer seems to be working. It appears that the scoreboard is from a Dynamo air hockey table. The main control board is what I am looking to replace. It is from 1989 and says “air hockey v3” If anyone can help me figure out where to find one(I can’t find any anywhere) I would be very great full
