Hello.......
i need help to improve my circuit
Wanted to make a clap on clap off circuit, and i found lots of circuit on the net,,
But most of them required ic's and resistors which i wasn't able to find
and some worked as timers, switching without any signal and turning off automatically
I then found a Bi-stable circuit using 555 ic with two buttons, reset and set which worked well as on when set is pressed and off when reset is pressed, I want to replace the two buttons with transistors, mic and a relay, to make a clap on off switch
whereby if a mic detects a clap signal it sends it to the mic amp,
mic amp output goes to Q1'S base through a relay to N/C which is connected to Q1,
Q1 switcthes on hence triggering the set button
which triggers the 555 IC and the IC's output activates a relay trough R2 and Q3 which changes the relay state from N/C to N/O, i.e from base of Q1 to base of Q2 , so that.... the next clap signal will trigger the reset button through Q2
Hope it can work!!!!
am having trouble with mic amp circuit
Some ideas please
This is the schematic
Some ideas please
