Hi guys,
I looked on the internet that dynamic memory allocation is not suitable for small Microcontroller But I need to understand the information given in this page https://www.geeksforgeeks.org/dynamic-memory-allocation-in-c-using-malloc-calloc-free-and-realloc/
I am trying to understand following paragraph
As it can be seen that the length (size) of the array above made is 9. But what if there is a requirement to change this length (size). For Example,
There is no such example coming in my mind that changes the length of array. What are the real time situation where length of array may be change ?
- If there is a situation where only 5 elements are needed to be entered in this array. In this case, the remaining 4 indices are just wasting memory in this array. So there is a requirement to lessen the length (size) of the array from 9 to 5.
- Take another situation. In this, there is an array of 9 elements with all 9 indices filled. But there is a need to enter 3 more elements in this array. In this case 3 indices more are required. So the length (size) of the array needs to be changed from 9 to 12.
