This is in regard to a failed Lorex LNR 4082 security camera DVR. One possibility is the power supply. See attached photo. The label says the DC output is either 12v or 52v. I suspect the former is for 120VAC input and the latter for 24VAC input. Don't know for sure.
There are lots of YouTube videos of testing desktop PC power supplies. This this one is quite a bit different, and I don't really know which wire pairs to test.
As you can see, there are 2 cable bundles:
(a) one with 2 black and 2 yellow wires
(b) another with a red and a white wire.
Suspecting black is ground, I tested black to yellow, getting 10.8VDC.
Also tested white to red (0 V), black to white(0 V ), and black to red (0 V).
From this I surmise that power is provided through black & yellow, and the voltage is too low. And perhaps the red & white pair is connected to an on/off control button.
So, am I correct?
BTW, I posted earlier on another possible culprit, a possibly heat-damaged board component.
So, am I correct?
