W
Wilhelm Lehmann
Hi all,
I was wondering if anyone has had any experience with DVI-I monitors /
signals.
I am trying to make a dongle or cable that can put the DVI monitor in
suspend mode (or DPMS off)
from the DVI specs ( http://www.ddwg.org ) I see on page 19 there is an
"Active-Off Power State" and states that the monitor can leave this state
(ie switch on) when "The DDC +5 volt signal is removed"
I take it to put the monitor into this state you have to apply the DDC 5+
Volt ?
Page 23 (signal list) there is a +5V Power signal, but what is this ? Is
this what I am looking for ?
On the old Analouge VGA monitors I achieved switch off / on by cutting the
Sync line with a relay. The monitor then says "no signal" and goes into
power save mode.
If I can put the monitor in suspend mode by cuting a single line, which line
will be best ? Maybe the DDC Data ? The pdf also states the monitor should
considder "no signal" when the freq is wrong ?
Any help would be appreciated
Just a note on why ....
Public Computer access is needed, where the need exists to limit time spend
on the computer but disabling mouse / keyboard etc is tricky, hardware wise
as the pc's sometimes hangs when the kb / mouse signals are interrupted,
software can be bypassed, so the easiest is switch the screen off, and
aparently the screens will last longer if you just put them in suspend mode.
Regards
Wilhelm
signals.
Volt ?
power save mode.
Regards
Wilhelm
