I just replaced a spindle motor in a Sony DVD player. Before I removed
the defective motor I was very careful to note the clearance between
the bottom of the plastic piece that the disc sits on when it rotates,
and the top of the housing that the motor is mounted to. I did this by
using a drill bit as a feeler guage before pulling this little disc off
the defective motor shaft when I removed it from the unit. Naturally I
reassembled everything in the reverse order maintaining the same
clearance with the new motor. The new motor spun up ok but would not
read the disc until (after some tweaking with the clearance) I
decreased it a bit more than it originally was. At that point the disc
read fine and the job it seems was finished. A couple of things disturb
me though. For one the final adjustment was done by pure guess work and
although it seems to work just fine, (I have watched through a complete
movie and listened to CD's on this unit), how do I know if the position
of the disc relative to the laser unit is dead center or marginal? Just
how critical is this clearance? Is there some room for a certain amount
of error here? And also what is the correct procedure for doing this
replacement? Thanks, Lenny Stein, Barlen Electronics.
