N_Cook
50V , low wattage lamp (or seriesed lower V ones) (assuming normal testing
is 10 to 20W range) to visually show if the volume is set too high, also if
high level high f oscillation on the output; sacrificial, fusewise, if
overdriven.
AC voltmeter , preferably autoranging for possible overload situation, to
measure/long term monitor the RMS power.
High power speaker pot (plus droppers) leading to a low quality ,
sacrificial ( for intitial maybe problematic testing) small speaker, for
basic possible intermittant sound, on/off, indication. Can be switched out
by plugging in a good quality speaker for audio monitoring of quality of
sound issues in otherwise known good amp.
Provision for coupling in a scope for distortion monitoring, when necessary.
Any other add-ons that others know of ?
overdriven.
