Jan Panteltje wrote:
On a sunny day (Mon, 02 Aug 2010 15:08:20 -0700) it happened Joerg
On a sunny day (Mon, 02 Aug 2010 13:36:19 -0700) it happened
[email protected]>:
Right, do not pay for the advertising!
No, we fast forward through it. One box even has an advertising
FFW button that hops it 30sec at a time.
Good,. There exists soft with scene change detection too, IIRC.
Yeah, but it works well enough by hand. I am also rather good in
tuning it out in my head, reading up on stuff during the news when
the ads play.
Once I made the mistake to actually edit it out. Those are the
commercials I still remember, as I had to see them many times to get
start, and end, and audio, right in the editior
Very few ads remained in my gray cells. The only one I remember from the
six years I lived in NL is from Douwe Egberts "En dan is er koffie".
And also the source material counts, garbage in garbage out.
Dancing with the Stars from BBC is super material, you really
see a difference.
Now I am confused. If it was from BBC, then it must have been
original 25 fps . that reminds me of dropped frames and fast
pulldown, big problem with motion in a 30 fps country. Here the
movies just play 25 fps, no dropped frames, but they are slightly
shorter (original film was 24). The pitch of the audio is higher
too.
http://www.24p.com/conversion.htm
Oh, Jan, we live in the 21st century. The times when such major
events were recorded in an analog format are long gone.
Cannot follow you here, BBC was recorded at 25 fps (tape) or 24 fps
(film). You play at 30 fps (or 60), so you have to interpolate frames
and add those at irregular intervals. I have some Linux soft for
that, it works, but the motion is not as smooth as at the original
speed I think. Do you think digital does not know about frame rate?
The problem we had here with LCD TVs (seems to go away with better
sets) was that many sets were HD compatible but displayed the 25 fps
material at 30 fps, causing horrible horizontal irregular jumping of
the picture.
This is what's cooking these days:
http://www.ikegami.com/br/products/hdtv/pdf/HDK77EX0401s.pdf
Most modern cameras can be switched so you can record in several native
frame rate standards:
http://www.ikegami.com/br/products/hdtv/hdtv_camera_frame1.html
I don't know how they do it but there is no interpolation at all. I
believe they record in US format because the participants are mostly
American, so it's for our market. The judges are one American, one
British and one (rather hot-blooded ...) Italian.
It's the level of the nerd factor. A big honking PC in the living
room requires one almost not to be married. A small one is ok, but
only if freshly married or close to the 50th anniversary
I think you still do not get the concept. I am not a fan of VDR, but
have a look at Klaus his website:
http://www.tvdr.de/ It does not
have to be a 'big honking PC'. ...
It is pretty big. Anyhow, ours has the described features as well or
pretty close:
http://www.tvdr.de/software.htm
Except we have to swap out the disk after x hours. Ok, no big deal.
... My media centre PC is not in the
living room. There is no need for that, most modern TVs can access
files on the media server, via a menu (and ethernet). There are cheap
interface boxes available these days with HD output and ethernet
connection for any room you want. In fact, with all those standards
constantly changing, the best bet is to split everything up, monitor,
receiver, disks, DVD burner. At least something will be of use a bit
longer then the 2 to 5 years we now have between a system change, 3D
is here hoopla, we just had HD . Do you have your 3D set yet?
No, and no need to. Same with BlueRay. Since we are into older movies
and don't like games or scifi there would be no use for that here. We
rather spend that money at the Japanese restaurant, like today
