Hello,
I am pretty much a dumbass when it comes to electronics, so excuse my ( current ) stupidity
I have a couple of questions that I hope someone can help me with whilst I try to relearn what i should have learned in physics, instead of drawing pics of my teacher and looking out the window!
I am running a 60w lamp, and a Roland TD-6 electronic drum kit, off a 12v leisure battery, via an inverter. I only plug in one of these at a time. The drum kit has an ac transformer plugged into the inverter, at 9v 1200ma.
I want to get rid of the inverter, keep the battery topped up with a decent sized solar panel, and connect a small led lighting circuit to the battery ( I think I can manage that), and it is clearly ridiculous to go from DC 12v to AC 240, and then back down to DC 9V for the drum kit, so I want to power that device straight from the battery.
Firstly, I have ‘blown’ three AC transformers with this setup, and would like to understand why this is. On a full charge the drum kit works beautifully. When the battery voltage drops to around 12.3v ( I keep an eye on it and endeavour to recharge it around this time ), and I plug in the drum machine, the display flickers. It will either flicker faster and faster until it starts, or it will just continue flickering until I give up and turn it off and back on. At this point I discover that the ac adapter no longer works. However, if I plug in the 60w bulb it will continue to give clear, consistent light. Huh? What the hell? How do I break an ac adapter with not enough power?
My second question is related to bypassing the need for an ac adapter. Can I take a + and – off the battery and power the drum kit that way? I’m guessing I’d need an inline fuse and some kind of voltage regulator to drop from 12v to 9v. But, I don’t want to shaft my drumkit. This might sound like a dumb question but I’m asking for advice because I am basically a monkey that can memorise how to connect things together – but has no idea how they work.
Thanks in advance…I realize that you might get a lot of dumb questions on here, but I am going to sit down and learn the rudiments of electronics properly in the next couple of weeks, honest!
Cheers
Spoonman
Cheers
Spoonman
